Structo wrote:I'm wondering if the hot transformers are more a product of the power tubes transferring heat.
After an hour or so of operation, those tubes get cooking hot and could be transferring heat to all around them.
Especially in a tubes down amp.
No, definitely not heat from the power tubes in my case. To reiterate, I've built 6 non-master volume  amps with these, they all get hot when cranked up for a while, even when I'm using the 100-watt Marshall PT in a 50-watt. The rectifier, and filtering I'm using is also what's shown in the schem/datasheet that the company provides. I emailed the company, and they said:
"Yes, these are built to withstand high continuous running temperatures without any problems. All of the magnetic wire and layer insulation in this unit is rated for these high temperatures. It is normal for these particular units to run hot. Please rest assured that these should perform well for you."
M Fowler, seems to me like a) your not pushing 2204's the amp very hard or b) the 50-watt PT runs cooler for some reason, as I've only used 100-watts PTs or c) I have been using a different run where thinner gauge wire was used. I've noted that all wires except the heaters has been 22 AWG, which is surprisingly thin, especially for the 120VAC primaries.
Thanks for any more thoughts, I'm still curious why people are having different experiences with these. But again, I've had no failures, and highly recommended these!
