Has anyone here built a D-circuit with reverb and active effects loop
all in the same chassis? Similar to a Two Rock amp.
Are you happy with the results?
Any layouts available?
I was playing my friend's older Two Rock.
It's the Amethyst signature with the switchable 6V6 single ended
output in conjunction with the 2- 6L6 power stage.
I enjoyed the added reverb and though the amp sounds good without it,
there was something special about adding a subtle amount of the effect.
Any thoughts would be appreciated.
						Reverb and Active Effects Loop in a D-circuit
Re: Reverb and Active Effects Loop in a D-circuit
I also would like to know how to do that. Thanks
				bluesfendermanblues
You could consider buying a Fuchs Verbrator.
It's an active loop probably very inspired by the Dumblelator. It has both serial and parallel operationand it has digital reverb parallel to the loop.
I don't have one myself, but I think it's reasonably priced......a DIY dumblelator w/o reverb wil probably cost more.
There are a handful of guys here that have built in a one tube reverb and one tube Dumbleator into their amps.
So that makes 5 preamp tubes total, so you have to make sure your chassis is big enough before tackling it.
For a really good quality reverb and loop you need 6 9 pin tubes to do it
1. Preamp
2. OD
3. Loop
4. Reverb Driver
5. Reverb recovery
6. Phase Invertor
That's why a scrapped 2 channel Fender makes for a good donor amp.
									1. Preamp
2. OD
3. Loop
4. Reverb Driver
5. Reverb recovery
6. Phase Invertor
www.RedPlateAmps.com
I have one build with an integrated single tube reverb with a medium decay Accutronics tank, not so stellar sounding but OK for adding a little depth in a small room, reverb almost inaudible in the full band setting.
Recently I have been experimenting with a D-Lator with a parallel two-tube reverb in a single rack unit with a long-decay Accutronics tank - awesome sounding reverb unit, but can't get a "small" room sound out of it. The next step is to swap the tanks and get a feel for how much that affects the outcome vs. the single tube driver vs. the paralleled full AT7 driving. Was also going to experiment with a "dwell" control to adjust the amount of drive as well.
Bill
Bill
Henry,heisthl wrote:For a really good quality reverb and loop you need 6 9 pin tubes to do it
1. Preamp
2. OD
3. Loop
4. Reverb Driver
5. Reverb recovery
6. Phase Invertor
Is it best to have the effects chain in this same order (loop, then the verb)? Is this also a one knob verb? I am doing a Twin conversion and may do the verb if laziness doesn't set in
I like reverb last because I like reverb on the delay rather than the reverse.
