Bias test points and HV fusing question
llemtt
Re: Bias test points and HV fusing question
Post by llemtt »
Tom, a fast-blow right before the plate supply caps usually blows as soon as you turn on the amp due to the high charging currents of the first cycles.
It would be better between the plate supply caps and the OT but I never tried such a solution while I reverted to a slow-blow (actually two) before the caps.
Teo
I have several Marshall schematics that show a 500ma fuse on the HT right before the choke.
Maybe it is a slo blo, not sure but that is where they have it.
But it is after the plate filter.
Here is a JCM 800 Lead 50w
Tonegeek
Post by Tonegeek »
Structo wrote:I have several Marshall schematics that show a 500ma fuse on the HT right before the choke.
After the filter is the key, I think. I will go with that or the CT. Its easy enough to reroute if I don't like it.
Pitcher Amplification
http://pitcheramps.com
llemtt
Post by llemtt »
After the filter as per the schematic you posted it's ok with a fast-blow
CT or pre-filter as per the attached schema of a reissue plexi 50 requires a slow-blow
Teo
