Princeton project suggestions
Hi all,
I have a butchered Princeton (no reverb) It needs new transformers (PT and OT, suggestions welcome). And I want to have a little fun with it as a project amp.
I'm thinking a 'Dumblish' inspired amp. I looked at the D'lite schematics/layout.. But will it fit in the chassis?
Any cool ideas/links to simular projects welcome.
Crank it up
Re: Princeton project suggestions
Normster built a 16x8x2 D'lite and his layout is floating around I can load up later so it will fit into a Princeton chassis no problem.
The Princeton chassis makes a perfect platform for Normster's Rocket Reverb octal power tube amp. The chassis has the correct number of tube holes for that.
A few years ago I bought a '69 Princeton for $40 US. I have to be honest and say that, for its size, it was the most lifeless and anemic classic amp I've ever played through (I also have a much-loved old Princeton Reverb so it's not just the brand). I wanted some compact power so I cleared the board and created a hybrid '59 Bassman power amp with a 763-era Super preamp. I was able to use all the old caps, most of the resistors that were still in spec, and installed a choke, biased for Sovtek wafer-base 5881s and added a Deluxe OT. The frequency response is very even so I use this little amp with both my rack and my acoustic rig.
I am building an amp now that uses a Princeton chassis. It is indeed quite small but if you take your time and plan things out you can fit a whole lot in them.
On my build I got, clean channel, OD channel, one tube reverb, tube recto, FX loop with switchable buffering, two relays and a separate PSU for them. Lots of iron, 5 pieces total, 50W OT (big!).
If you look in the Dumble files section you can find some rough layouts for a PR ODS.
I just did a PR with a IFR820 source follower added to the trem circuit (and with much better filtering than the 'one-can' method). It has a 6k6 Pr Z OT and idles at about 430 with a pair of JJ6V6S driving a weber Sig12S. I did my own layout, and I did the grounding as per Merlin's excellent article on separating all the ground return paths to their respective filter cap ground returns. It is a quiet as a mouse when not singing, and otherwise everything about it sounds a heck of a blues machine (and it got a good workout at the blues club last nite).
- Sonny ReVerb
Well, here's what you can do with a Princeton chassis - a la Henry:
https://tubeamparchive.com/viewtopic.php?t=1979
and here's what he can do with a Champ chassis:
https://tubeamparchive.com/viewtopic.php?t=3068
"The blues is the roots, the rest is the fruits." - Willie Dixon
- David Root
Try a 50W #40 Dumble w/out loop (no room for 4th 12AX7 unless you get real creative). It would be better with Normster's built in loop (see his '97 ODS layout).
I did this in a BFP Reverb chassis (which has the 4th 12AX7 slot) and it is killer! Actually a #13/#40 cross w/ carbon comps in the OD circuit.
BF Bassman iron!
BF Bassman iron!
Nice ideas guys! Will make some decisions, buy some part and start builder after the summer!
Thanks!
Any experience with >50W 10" speakers?
Thanks!
Crank it up
Here is the Normster Rocket Reverb I was talking about.
David great looking build
- David Root
Thanx MF! Until I get my #124 tweaked and de-fizzed, it is I think the best sounding amp I have ever built.
