Black beauties
passfan
Black beauties
Post by passfan »
I've got a handful of .047/400v beauties and I'm going to use one in a Tele I just picked up. I'm wondering what the single red stripe signifies on one end and which direction this should go?
"It Happens"
Forrest Gump
Re: Black beauties
The stripe is likely the outer foil indicator. Read here:
http://www.aikenamps.com/OutsideFoil.htm
billyz
Re: Black beauties
Post by billyz »
That's what I have in my Nocaster, wondeful. I don't think in a Tele it really matters which way you put them in. The stripe may or may not tell you which end is what anyway. you would have to test them.
If you think it matters then clip them in and switch it around a few times to determine the best sound.
Better pots which make a huge difference too. I tried a few sets of CTS pots and none really did it for me until I put in a set of Alesandro PEC pots. Now volume and tone swells do the Magic stuff along with the BB cap.
CE electronics has the 1 w pec's now too, which should fit and perform like the Alesandro's.
8)
vibratoking
Re: Black beauties
Post by vibratoking »
Wow...I checked out the Alessandro website. Can't wait to pay $50 for a pot and $20 for a cap. Am I out of touch or are those prices a blatant ripoff?
Re: Black beauties
Just buy the PEC.
I have a suspicion that is all the Alesandro pots are anyway.
Re: Black beauties
.....and don't forget the Alessandro special wire to go along with those customy PEC pots. :)
billyz
Re: Black beauties
Post by billyz »
The Alessandro's are stupid expensive but. I just was not happy with everything else I tried. I even contacted PEC to have some made and they were just as expensive . That was then, now the 1 watters are available thanks to CE. And they did make a difference , unless you just set em and forget em. I look at it this way, on a 2 or 3k guitar, $50 for the best pots ( which get worked a lot) is a small thing.
If you are trying to get the Roy Buchanan thing, you will appreciate a great pot taper. 8)
selloutrr
Re: Black beauties
Post by selloutrr »
My Daughter Build Stone Henge
Re: Black beauties
Nevermind.
BobW
Re: Black beauties
Post by BobW »
And that's exactly what they are hoping you'll think.
jelle
Re: Black beauties
Post by jelle »
In that view, I wouldn't mind to pay 10 bucks per screw 'since these hold all the pieces together'.
:lol:
solderstain
Re: Black beauties
Post by solderstain »
billyz wrote:I don't think in a [anything] it really matters which way you put them in. The stripe may or may not tell you which end is what anyway. you would have to test them.
It's simple: It doesn't matter. Sprague Black Beauties aren't polarized and the signal coming out of a guitar is a passive AC signal. 8)
Jana
Re: Black beauties
Post by Jana »
I don't know what the marking on the Black Beauties signifies. Most times it represents the outer foil--you will have to test that to make sure.
It does matter which way they go, not from a tonal perspective or electrical polarizing issue, but for noise. The outer foil should be connected to the lower impedance connection. For a tone control in a guitar this would be the grounded side. If it was a cathode bypass cap, once again, the grounded side. If it was a coupling cap between stages then it would be connected to the plate--the plate is the lower impedance side compared to the grid of the following stage. It's purely for noise issues and having the outer foil connected to the lower impedance side of the circuit to act as a shield.
