Filament grounding
Filament grounding
Why did Had ground the filaments with 120 r resistors. The ceriatone layout don`t show any resistors on the filaments.
						- David Root
Re: Filament grounding
Does the Ceriatone power transformer have a center tap on the heater winding that is grounded to the chassis? If it does that is doing essentially the same thing.
Yes it has a center tap to ground. but I`m not building a ceriatone, just looking at the layout, and on the hammond PT I use(290FEX), I´m not sure if there are center tap. Do I need to use those resistors to ground if I don`t have a center tap?David Root wrote:Does the Ceriatone power transformer have a center tap on the heater winding that is grounded to the chassis? If it does that is doing essentially the same thing.
You need to be clear about which amp you are referring to.
There isn't just one Dumble amp.
I`m building a ODS, 100w, el 34, non hrm, Hammond Twin, dual showman PT, hammond Marshall OT. Pretty much a #0124 on the preamp side. skyliner tonestack.Structo wrote:You need to be clear about which amp you are referring to.
There isn't just one Dumble amp. :wink:
According to Hammond's web-site there is no heater center tap on the 290FEX transformer.
http://www.hammondmfg.com/pdf/EDB291FEX.pdf
Deric®
Thanks!Deric wrote:According to Hammond's web-site there is no heater center tap on the 290FEX transformer.
Anyone who knows what the org wire are for. I did ground that one. Is that correct!
Thanks again! :)Deric wrote:The orange is a shield. It should be grounded.
Frank.
Frank.
