The amp started life 18 months ago as a stock High Plate ODS 101 in a Funk chassis and having gone through many changes, has ended up back at the start except that it has 180K resistor fed from the .005uf cap on OD2 plate, 47pF on the MV for use with D'lator. OD trimmer is set to @ 24k to ground.
V1 voltages are @ 190v and V2 @ 205v. Bypass caps are all 5uF.
The clips were recorded with a borrowed TC interface into Cubase at home, so if you have any tips on how I could make improvements here, they will be graciously received.
I used my home made chambered guitar in bridge pos. with a JB humbucker for clips 2/3. Clip 1 uses the same guitar but with coil tapped '59 neck p/u.
I used my home made 1x12 EVM-L ported cab.
A D'lator was used on clips 1 and 2 and the D'lator recovery was used as a MV. They were recorded at low ish volume. So no controllable feedback. I've only ever managed that by using a boost pedal. I would love to know how others achieve this on their clips!
Please excuse the frequent clams.
Thanks for listening.
Paul.
PS. As always, many thanks to all the esteemed members who have helped me out big time already.
