Express Build Started
Well after a long time I have taken the plunge and started my Express build. I started by shopping at Allyn's last night. When done I am going to contact my friend Nat (the owner of Francesca) and see if I can get a comparison.
philmanatee
Re: Express Build Started
Cool! I'm excited to hear about the comparison. I had a tech that played on one of the early express's tell me mine nailed the sound. You should have many late solder filled nights ahead of you! Phil
I'm sure. I can't wait to get building.
Good luck with your build!
i'll keep you guys posted
Schematic?
I'm new to the site and have looked for a schematic of Francesca (was told there is one).
Can someone rub my nose in it, evidently I can't sniff it out?
Also, is there a list of voltage measurements for this particular amp?
Actually, what you want is the Kelly schematic:
https://tubeamparchive.com/files/kelly90schemlayout.zip
Franchesca just confirmed that the Kelly schem was basically right. Make sure you get the latest correction of the bias circuit, it was the only error...
The only Layout that I know of is the fixed ceriatone one. Richie changed the values to match the Kelly '90 schematic which is the same as Francesca and correct. You can download the Francesca pics from the DL section and use them as a guide. Here's the layout:
Allynmey
Allynmey
so the Kelly '90 and Francesca are the same amp?Allynmey wrote:Richie changed the values to match the Kelly '90 schematic which is the same as Francesca and correct.
Rockstah Amps: http://www.rockstahamps.com
Rockstah Amps Youtube: http://www.youtube.com/user/RockstahAmps
Builds and modification sound files: http://www.soundclick.com/rockstahplexitweaksandmods
Here is a link to the Kelly90 schematic that includes all fixes to make it exactly like Franchesca.
https://tubeamparchive.com/download/file.php?id=776
One more thing...The filter caps are 20uF and 40uF not 22 and 47uF.
Allynmey
Allynmey
so in other words there is no correct schematic for Francesca? or did i miss something?
The schematic I posted above is the Franchesca Schematic. I took the Kelly 90 schematic and corrected all of the problems to make it exactly like Franchesca.
ill go by THIS schematic then! - build started!UR12 wrote:Here is a link to the Kelly90 schematic that includes all fixes to make it exactly like Franchesca.
philmanatee
Right on rockstah! Your gonna love the express. Phil
