Dumbleator finish, voltage
Hi all, Today I completed my first dumbleator , I have not tried yet....
This is my schematic with voltage:
I will post some photos..
Re: Dumbleator finish, voltage
Hi Sergio,
Looking forward to seeing your loop.
I notice a lot of you guys over there use the toroid transformers.
Is there a reason for that?
I was wondering why you chose to use a 51K plate load resistor on the Recovery plate?
I have similar voltages but my plate voltage on the recovery plate is 213v using a 100K plate load resistor.
Did you find you liked the way it sounds better with lower gain there?
Here is what I ended up with.
what type of toroid transformer gives me the chance to put it inside the rack
height only 34mm
I read old posts (I forget which) that the voltage on the second triode (recovery plate) should be around 250v for the proper functioning
maybe I'm wrong, but I remember this...please correct me if this is wrong
100K there I think to run with too low voltage.
Tomorrow I will try my D-lator and I'll let you know.
Ciao!
height only 34mm
Ciao!
230V or so is the standard.
I'd lower the B+ dropper to raise the plate voltage and go to the 100K. The plate resistor is an integral part of the tone and a low plate will have less bass and be brighter. It changes other things too.
Stick with the 100K.....
Btw, 210V also sounds good.
Sergio
The voltage drop across the plate resistor sets the rails on the recovery stage...The higher the value the greater the voltage drop.. Greater the drop the darker the tone as well as increased headroom..Think high plate low plate.. Same basic result.. Like Scott say's change that resistor.. Tone changes along with the headroom on the recovery..Good Luck!!
thanks to everyone for the advice
Sergio
Sergio
I changed plate resistor on recovery stage with 100K , here my new voltage. and some photo
Looks very nice!
How do you like it with your amp?
That 's a great job Sergio.
yes it is; I did a 2R2 resistor in series to drop the voltage a little. The torrodial is designed to feed 3 to 4 pre amp tubes.Structo wrote:Your heater voltage is a bit high, eh?
For the dlator only one tube, that's why the heater voltage is a bit high.
I try it today , it's sounds good with the pots setted high , nothing change of tone.
Yes , my heater voltage is a bit high.
Erwin , you suggest me a 2R2 in series on every HT wire? I understand right?
Sergio
Sergio
Guitarman18
Sergio,
Check this out for sorting out your heater voltage.
http://www.tubecad.com/july2000/page2.html
So, according to my maths, 1R2 resistors in series with each leg of the heater winding.
Paul.
BTW, HT stands for high tension (which is the high voltage secondaries), not heaters (6.3).you suggest me a 2R2 in series on every HT wire
Paul.
No I meant 2R2 (3w)in series with the heater wires. This would drop your voltage to 6,3v.sergio wrote:I try it today , it's sounds good with the pots setted high , nothing change of tone.
Sergio
Excuse me , OK , HT = high tension (high voltage secondaries)
I will try to insert a resistor in every heater wire.
Ser.
Ser.
