hi dave, thanks for your input,dave g wrote:The clean to mean has nothing to do with exceeding the rated limits of the PT. No way in hell are two EL34s ever going to average 300mA. Even if you could manage to pull that much current, it's not going to sound cool. It's going to turn your power transformer into a chimney and probably trip a circuit breaker.
The clean to mean has just about everything to do with that 1K dropping resistor in the power supply between the plate and screen nodes. When you hit the power tubes with a large signal the screen current spikes, causing a voltage drop across that resistor that propagates to the preamp, changing the operating point of the PI and 3rd clipping stage and causing them to compress/limit more. You could even think of it as a weird sort of negative feedback mechanism.
You cannot completely replicate this in a SE design, because the output tube(s) are biased in class A and will be drawing too much current at idle. In a push pull power amp, both output tubes are biased near cutoff, so you are drawing far less current at idle, which means that the drop across that 1k resistor is comparatively small. That's really what the clean-to-mean boils down to; for smaller signals seen by the output tubes, the headroom of the preceding clipping stages (PI + 3rd stage) is relatively high. Increase the signal strength enough, and the headroom of those stages falls, leading to a voltage limiting compression effect.
so if the clean to mean is a product of the sag from the dropping resistor, how can i get this to be repicated as near as possible in a single ended amp.
can i measure how much the voltage drops as i play???
