Opinions: reverb before or after fx loop?
markusw
Post by markusw »
Suppose it's a matter of taste.
For me with e.g. a chorus in the fx loop it would somehow make sense to have the reverb after the loop.
Thanks in advance for your opinios :wink:
Regards,
Markus
Re: Opinions: reverb before or after fx loop?
I have a delay-chorus-reverb pedal through my Dumbleator.
Works great! :D
markusw
Post by markusw »
So you first have delay, then chorus, then reverb?
Did you ever try to put e.g. delay and chorus after the reverb?
In my two builds I put a single tube reverb after the loop.
As far as I know in the D'lite the reverb is before the send jack.....
markusw wrote:So you first have delay, then chorus, then reverb?
I don't have a built in reverb.
I have the two passive jacks on the amp which I connect to the D'lator.
I did experiment with the signal chain in the loop and the way I have it sounds the best.
markusw
Post by markusw »
Sorry for the misunderstanding. That's exactly what I meant.
Whether you changed the order within your fx unit.
Thanks. Seems my decision to put the reverb after the fx loop wasn't a bad one :D
