geoffrod wrote:Hi all,
I have built my sewreckish amp, but i have a terrible buzz with nothing plugged into the input, plugging a guitar in reduces it somewhat, but the whole chassis is microphonic, tapping on the chassis with my chopsticks can get the ossilation going as well, the whole chassis being microphonic makes every noise get amplified thru to the speaker even with the volume turned down to off.
I have some wierd voltages as well,
B+= 337V
B2= 330V
B3= 279V
B4= 254V
V1b =
Pin6= 156V
pin8= 1.48V
V1a
pin1 = 182v
pin3 = 1.9v
V2a =
pin1 = 237v
pin3 = 2.95v
V2b =
pin6 = 156v
pin8 = 25v
6v6
pin3 = 279v
pin4 = 315v
pin5 = 330v
pin8 = 57v
If anyone could have a look at these voltages and give me some comments, it would be greatly appreciated.
the starge voltages to me are the differences in pin 1 and pin 6 on V1, they come off the same node, thru exactly the same size 100k resistors  yet one has a voltage of 156v and the other 182v???
and also the bigger difference between the v2 pin 1 and 6
and also the cathode voltage on v2b, 25V????
then the power tube, cathode voltage doesn't seem right at 57v????
i am not sure if there may be problems with my coupling caps leaking maybe???
cheers
geoff
Edit;
ok so i just played my guitar thru it and apart from the buzz, it seems as though the caps are draining, and i loose sound and volume.
Ok so i solved my noisy buzz with nothing plugged in, put a switched jack in the input.
still a bit noisy when i plug into it though, (something to work on).
Here is the wierd thing though. I play my guitar thru itwhen i first turn it on, seems ok until i dig in or try to sustain a note, and the sound bleeds away like the caps are draining when you turn the amp off,then the amp goes dead quiet, that quiet you think it has blown a fuse or something, until you dig in again, i get sound, but this time it bleeds off quicker.
To me it sounds like my caps are draining far to quickly and the power supply cant keep up, What could be the cause of this????
it also seems like if i leave it for long enough the caps fill back up and the noisyness comes back.
i have gotten rid on the microphonic chassis, replaced the first ecc83.
Anyone got any suggestions.
they would be greatly appreciated.
cheers
Geoff
