3.15AC-0V-3.15AC
3.15AC-0V-3.15AC
Question, I just got my Marstran power/output transformers for my Express build and haven't been able to contact Brian Wallace the past day or so. So I thought I'd ask a question here. According to the wiring diagram on the Marstran site for "Marstran TW Power Transformer" the diagram for the secondary side has taps for 3.15 V, 0 V & 3.15V. I'm familiar with the 6.3v-CT-6.3V setup for all the other amps I've built but I am not sure what to do with this 3.15V-0-3.15V type of arrangement. Any ideas?
Re: 3.15AC-0V-3.15AC
Maybe I'll answer my own question. The Marstran transformer has a tap for 3.15 & 3.15 which = 6.3 VAC accross the two wires. All the transformer diagrams I have seen show a 6.3 tap with an arrow to the other 6.3 tap, therefore 6.3 VAC. The 3.15 tap with no arrow to the other 3.15 tap faked me out I guess! To top it off I've been a designer/draftsman for 30 years and look at stuff like this every day
You've done well Piperbob.
Normally you can just ground the centertap and I believe that is what they actually show in the layout.
"It Happens"
Forrest Gump
Forrest Gump
The only difference is the specification terminology.
Brian correctly specifies his transformers as 3.15-0-3.15V, which is correct.
Others may be specified 6.3V centre-tapped, which would also be correct, as this implies 6.3V across the secondary with a centre-tap in the middle, so also 3.15-0-3.15V.
Specifying 6.3-0-6.3V would actually be incorrect as this would imply a 12.6V secondary, which isn't likely.
I actually have a PT out of an old Conn organ chassis with this exact winding in it. I inadvertantly (more like a dumbass) lit up all my Rocket bottles for a couple minutes, before I realized it, across the whole winding. My 34's won't go to half volume now without crackling.paulster wrote:The only difference is the specification terminology.
"It Happens"
Forrest Gump
Forrest Gump
You've won respect and admiration!!!piperbob wrote:Do I get a prize?
"It Happens"
Forrest Gump
Forrest Gump
I once watched a job superintendant and foreman from a large electrical contractor with over 50 years of experience between them try to figure out how to hook up a single phase secondary winding on a transformer. They didn't know where to hook up the neutral and were afraid that XO would short out the whole secondary. Didn't understand anything about the winding resistance representing a load and not a short, or any of the like. They actually called the manufacturer to ask????piperbob wrote:Maybe I'll answer my own question. The Marstran transformer has a tap for 3.15 & 3.15 which = 6.3 VAC accross the two wires. All the transformer diagrams I have seen show a 6.3 tap with an arrow to the other 6.3 tap, therefore 6.3 VAC. The 3.15 tap with no arrow to the other 3.15 tap faked me out I guess! To top it off I've been a designer/draftsman for 30 years and look at stuff like this every day
"It Happens"
Forrest Gump
Forrest Gump
passfan wrote:
True. Now and then I have to supervise people at work to help me get a job done. I have much more respect for someone that asks a lot of questions rather than someone assuming a bunch of things and coming up to me and saying "I'm done now what? and giving me something I didn't ask for and can't recognize. I get asked questions all the time that I can't answer. I don't mind saying "I don't know". Watch out for the know it all types. The road to hell is paved with good intentions.the only dumb question is the one you don't ask, right?
