I don't think this question can be answered--at least not with an answer that will satisfy everyone.
If you believe in god and believe that god created all the creatures then where do genetically created life forms reside in the equation? Is Dolly the sheep an abomination or a cause for celebration?
If you are a collector that owns a TW and don't play the amp, chances are you are going to want the theory that only a TW voiced by KF (including the selection of tubes) is an original TW. As the other original TW amps are played and the tubes wear out there will be fewer and fewer "voiced by KF" amps available. The investment will continue to appreciate in value.
If you have a TW amp and are a player who uses the amp, then you will want the theory that it is the amp that is collectable and, with proper selection of replacement tubes, the amp will still be a TW voiced by KF. You can use the amp but still maintain the investment value.
If you don't own a TW but want to build a clone as good as the original, then you will probably want to believe that, with enough perseverance, the magic that KF imparted on his amps is discoverable and reproducible. There is a secret and with the knowledge of that secret a clone that is sonically indistinguishable from the original can be created.
The irony of the last theory is that, because the amp and it's original builder are acquiring such a mythic status, the "magic secret," if there is one, may turn out to be something so simple that it will be overlooked or discounted. If someone tries to reveal that secret that person will be guilty of heresy and burned at the stake for blasphemy.
So ends the sermon for today. If we could now turn to the hymnals located in the schematics section, we will all rejoice and make a joyous noise unto the lord.
