Seeing a few projects other members here built that are based on the Rocket intrigued me (KT66 power amp section etc), so I decided that I wanted to do something similar, but with some big bottles
On doing research on KT88's, I noticed a lot of designs and data sheet info are spec'd for ultra linear operation, and seeing as I have yet to experiment with KT88's or UL, I picked up a Triode A-431-S OPT, which is a hefty 4.3k tranny with UL taps.
In order to house these beasties and provide a lot of flexibility and room to build with, I went with a 100W Plexi-style chassis. I'm planning on wiring the 4 output tube sockets, but will only use only 2 of them with the KT88's; this leaves me flexibility in the future to drop 2 or 4 EL34's in there to mess around with. I'm also going to wire the OPT so I can switch between pentode & UL operation (powered off, of course) and a switchable voltage divider to provide the KT88 screen grids with the proper lower voltage in pentode mode.
To top things off, I'm adding a parallel 1st gain stage w/an ef86: this will be wired up like a jumpered Plexi, so each paralleled 1st gain stage (12ax7 & ef86) has it's own volume control so they can be mixed in any proportion.
I have drawn up a schematic, and would really appreciate if you could take a look at it and see if you find any errors or less-than-optimal connections/values. There's 2 areas that I'm not fully comfortable with:
Voltage divider on B+2: is this divider a good way to wire things to drop the B+2 to 250-300VDC for the screen grids in pentode mode, or am I way off? (this creates a bleeder for the caps also....) Any value/sizing suggestions, or alternate ways to achieve this voltage?
Mixer resistors/caps for V0 (ef86) and V1b (12ax7): this is reminiscent of how a Plexi (1959/1987/etc) achieves this function, but any ideas here would be cool. I don't know if the mixer setup as I have it will mess with the tone too much. I'd like the mixer to be as transparent as possible.
Any other input/suggestions are welcome as well. Thanks for your time!
[img
