Panel Light
loupy31
Panel Light
Post by loupy31 »
Hi All,
I have a Panel light for my TW Xpress build, Its is a 120vac, I am in australia and my PT is a 240vac, What resistor value do i need to make it compatable with 240vac.
Regards Peter
Cliff Schecht
Re: Panel Light
Post by Cliff Schecht »
You need the full operating temperature current draw of the pilot light to know what the resistor value should be. If you know this then the calculation is simply R=(240V-120V)/I, where I is current the light draws. The problem is that if the pilot light draws more than 50mA of current then you're looking at at least a 10W resistor and a big waste of power (although tube amps in general are a big waste of power ;)).
Cliff Schecht - Circuit P.I.
paulster
Re: Panel Light
Post by paulster »
Do you have a dual-primary PT, with 2x 120V primaries in series?
If so then just parallel the lamp across one of the primaries and it'll run happily at 120V.
loupy31
Re: Panel Light
Post by loupy31 »
My PT has 0, 100, 120, 220, 230, 240, taps, if I use 0 and 120, will that work ok?
peter
paulster
Re: Panel Light
Post by paulster »
Yep, that'll work fine.
