I'm in big dilemma which amp would be the best for me :S I would like to buy complete amp from Nik, but I can't decide
The music I listen and play is blues/rock like Led Zeppelin (yeah Pagey
Thank you very much!
My 18 watt is screaming loud!Mar]{o wrote:I was thinking a lot about wich amp to get - now I'm even more confusedI came on idea to build 18 watt tremolo kit from Nik - that would keep the cost even lower, but now I'm a little woried that 18 watt won't be loud enough... I don't think I'll be using it live without mic, but I want to use it without mic with band rehersals... Is that possible? Will it be enough loud? I plan to make it in 2x12 combo (something usual like one Greenback and one Vintage 30)...
Good to know. Need to try my Liverpool at rehearsal on Wednesday.geekmacdaddy wrote:Well,
I had a gig in a club last night, that had high ceilings, and was med size, a bit larger than medium...Used the 18watt Trex, and guess what? Not loud enough. I had it dimed most of the night, and it was there, but, not quite enough...damn....in a smaller room it would work. I'm thinking about 36 watt possibilities now, and or maybe liverpool....
Geek
GMD: were you using your Sammis? If so, a switch to more efficient speakers may have been just enough to do the trick.geekmacdaddy wrote:Well,
Geek
