Hey jaysgjaysg wrote:Assuming passive pickups, can we expand this to wiring approaches? I've got a Les Paul like guitar with Duncan 59 neck & JB bridge. The volume pots are wired Norlin era, but with bypass caps. Ignoring the TW issue, that's a very good setup, ime. Would I see improvement with 50's wiring and no bypass caps?
my edwards les paul had those pups exactly, after i did the 50's wiring
the vol & tone use-ability was much more apparent, with no need for treble bleed at all...big improvement
then I changed out the pups for Mick Brierley's pickups, and an even bigger improvement!!!
BTW Im running thru an express amp.
Cheers, Craig.
 dare to colour outside the lines .
