+1.vibratoking wrote:If you are stating that SMD is bad, I would suggest that you are confused about the real issues or you are brainwashed. SMD is better or every bit as good in almost all but very high voltage applications. Lower stray/parasitic capacitance and inductance make for a more robust, reliable and manufacturable design. Does SMD allow for a higher density of components in a given space? Yes. Is that a bad thing from a performance POV? No. Does it make it harder to repair? Yes. Learn to deal with it. All this stuff can be repaired. There is no magic to working on SMD loaded PCBs. It just takes some common sense. knowledge, and experience.
I like to use eyelet boards, through-plated PCBs for leaded components and SMD PCBs. It just depends on the particular application.
SMDs fine to work on if you've got the appropriate tools, in exactly the same way that you wouldn't work on a turret board with a blowtorch; you'd get the right tool for that too.
