Repurposing Trainwreck iron?
jaysg
Post by jaysg »
For example, I'm repackaging my 5e8-a with the wreck PT in a reverse Express chassis. Anyone else using those pieces in non-TW amps? How are you liking the results?
funkmeblue
Re: Repurposing Trainwreck iron?
Post by funkmeblue »
I haven't yet, been thinking about a rocket/bassman build....single channel bassman with rocket power section.....express tranny's
Zippy
Post by Zippy »
Some might argue that the Rockster 66 falls somewhere in that fuzzy space. Rocket pre into a cathode biased KT66 power section. I really like it.
I also enjoy my Rocket into 6L6 power section a worth while amp build. I currently have it tubes down in a Z 212 combo cabinet using G12H and 25w greenback.
Next will be the Normster Rocket Reverb I have to build that one and have been putting if off for too long.
keithrick
Post by keithrick »
I built a 4 6V6 amp using the Trainwreck iron and it turned out great! Copied the cowtipper front end (AB763) with a on board three knob reverb.
keithrick
Post by keithrick »
sorry double post
Andy Le Blanc
Post by Andy Le Blanc »
As long as you provide an appropriate load and voltage condition to the tubes
it really doesn't matter what or where the transformer came from.
lazymaryamps
