OC3 regulator
ckpop
OC3 regulator
Post by ckpop »
Many years ago I came across a modified fender in which someone used an OC3 regulator in combination with the power supply. I have to admit it really seemed out there as far as design for a guitar amp.
I guess in my research trying to figure out why someone would do this I found it was pretty close to a leslie power amp schematic.
Has anyone come across anything like this before ? The amp sounded amazing and not stiff sounding like most would think. with the constant voltage on the B+ of the output tubes it seemed the voltage swing on tubes was different then what you mostly see with other amps.
any insight on this subject ?
Andy Le Blanc
Re: OC3 regulator
Post by Andy Le Blanc »
In a fender?..... I've seen them in Gibsons. Might have been on the bias?
lazymaryamps
FUCHSAUDIO
Re: OC3 regulator
Post by FUCHSAUDIO »
Plush did this back in the day, as a series screen regulator. (They blinked purple on loud passages !) Think of it as a tube zener diode. Still available from New Sensor Sovtek branded. They contain Mercury, so don't break one.
