White Coax source??
White Coax source??
Anyone have a source for white coax cable?
						- Sonny ReVerb
Re: White Coax source??
RG-59 plenum comes in white with a 20 gauge solid center conductor. You can find it from lots of sources.
									"The blues is the roots, the rest is the fruits." - Willie Dixon
I get it from ApexJr.com. It Teflon so you can't melt it as well.
This is some of the best stuff
http://www.gotham.ch/en/index.php?secti ... tails&id=9
				bluesfendermanblues
Great link! what source would you suggest for the solid core cables for plate, cathode etc.?butwhatif wrote:This is some of the best stuff
						- Funkalicousgroove
The stuff apex has isn't the right stuff,  the capacitance is too low and the conductor is too small,   I have a 500ft roll of that stuff you can have for the cost of shipping.  The right stuff has a larger gauge,   I have some if you want,  I get a buck a foot.
						- Funkalicousgroove
Type mwc is a good choice, mil spec PVC jacket 1Kv rating.bluesfendermanblues wrote:Great link! what source would you suggest for the solid core cables for plate, cathode etc.?butwhatif wrote:This is some of the best stuff
Crap, I just recently re-wired my entire amp using the 18ga Teflon shielded cable from Apex.
But I don't feel my amp is overly bright.
- David Root
Now He Tells Me!
Just put eight coax runs in my new build of 24 and 22 ga Apex Jr. teflon coax too!
						- Funkalicousgroove
Fellas,  I'm sure it's fine,  no need to start gutting your rig!!
Solid core (suggested by some folks I think), or stranded?  Most (or all) of the pics of the real thing show stranded center conductor for the coax right?  Maybe or maybe not a big issue.
						- Funkalicousgroove
Stranded in the ones I've been in (coax anyway)  hookup wire was either Solid style 1090(300v pvc) or Yellow /green Stranded Teflon
				bluesfendermanblues
Can you pm me a mailing address?? I have a money order I'd like to send.Funkalicousgroove wrote:The stuff apex has isn't the right stuff, the capacitance is too low and the conductor is too small, I have a 500ft roll of that stuff you can have for the cost of shipping. The right stuff has a larger gauge, I have some if you want, I get a buck a foot.
