monkey 88 progress
leleduke
Re: monkey 88 progress
Post by leleduke »
Thanks. The only thing the cam didn't pickup was the picture frames falling off the wall :lol: the amp is very bass heavy.
MD
heisthl
Post by heisthl »
That amp sounds great - good work
www.RedPlateAmps.com
Blindog
Post by Blindog »
Nice job Mark 8) I still havn't got started on mine yet, had to have carpal tunnel surgury before the end of the year :x Definitley anxious to get going on it.
How did you set your HRM stack?
leleduke
Post by leleduke »
Blindog wrote:Nice job Mark 8) I still havn't got started on mine yet, had to have carpal tunnel surgury before the end of the year :x Definitley anxious to get going on it.
Thanks, the HRM stack is set pretty much flat ant the OD trimmer is set low at 20K to ground- 9:00
leleduke
Post by leleduke »
heisthl wrote:That amp sounds great - good work
Thank you, that means alot coming from you. :P
Was the reverb on the clip only from the amp or was delay or post reverb added?
If it was from the amps reverb it sounds really good, a little heavy on that cut but very Eric Johnsonish. :wink:
leleduke
Post by leleduke »
Structo wrote:Was the reverb on the clip only from the amp or was delay or post reverb added?
Its the verb from the amp. The delay really needs a dumbleator because the delay thins the tone of the amp some. I have a little dummy coming in soon from Moss.
MD
Man, that is good sounding verb then.
I thought you were adding it to the mix later or something.
Really a great sounding reverb.
Had that White Cliffs Of Dover thing going on.
leleduke
Post by leleduke »
The amp is only running on two OP tubes on the clips. I'm still waiting on parts and tubes from brownnote. I did notice that the delay in the loop sucks the low end I guess thats why I need a dumleator.
MD
Yes, I am currently building a Dumbleator.
I thought it would be a pretty quick project but as with anything unfamiliar, it is taking me longer than I expected.
I've had to do some fabrication to things to make them all come together.
I'm looking forward to hear it with my amp, so I hope it works right when I plug it in.
The one thing I am a little unsure of is how to work the controls and what plugs in where. :lol:
The schematic doesn't come with an owners manual. :lol:
Pete
Post by Pete »
INPUT & OUTPUT connect to the amp, SEND & RETURN to the effect if you use one. HTH
