 the amp is very bass heavy.
 the amp is very bass heavy.MD
 the amp is very bass heavy. I still havn't got started on mine yet,  had to have carpal tunnel surgury before the end of the year
     I still havn't got started on mine yet,  had to have carpal tunnel surgury before the end of the year  Definitley anxious to get going on it.
   Definitley anxious to get going on it.Thanks, the HRM stack is set pretty much flat ant the OD trimmer is set low at 20K to ground- 9:00Blindog wrote:Nice job MarkI still havn't got started on mine yet, had to have carpal tunnel surgury before the end of the year
How did you set your HRM stack?
Thank you, that means alot coming from you.heisthl wrote:That amp sounds great - good work
Its the verb from the amp. The delay really needs a dumbleator because the delay thins the tone of the amp some. I have a little dummy coming in soon from Moss.Structo wrote:Was the reverb on the clip only from the amp or was delay or post reverb added?
If it was from the amps reverb it sounds really good, a little heavy on that cut but very Eric Johnsonish.
