Two OD sections
mat
Re: Two OD sections
Post by mat »
heisthl wrote:
mat wrote:
1. Can I split the power tap going to OD1a and OD1b to the additional HRM OD section or should I have to add an extra filter caps/resistors for the new OD section ?
2. Should I really try this one or not ?
1. I didn't - I used a 27k off of v2 with a 40uf filter.
2. you should - you will need to invest some trial and error time on the 2nd OD entrance or it sounds like total garbage.
Thanks Heisthl ! I'll start the experimenting 8)
mat
heisthl
Re: Two OD sections
Post by heisthl »
Another clip of this type of amp: Strat with a delay between 2 mic's - intro is a strat not a rhodes! nasty raw recording - best if you EQ out some bass. All solo tones are using both OD sections on.
http://soundclick.com/share?songid=8458490
www.RedPlateAmps.com
j-po
Re: Two OD sections
Post by j-po »
mat wrote:I'll start the experimenting 8)
Awfully big job that is. So many variables with all the gainstages involved.
