Impedance switch
angelodp
Impedance switch
Post by angelodp »
Hi, since the NKK Imp switch is no longer avail, is it just the switch over at AE that makes the best sense? Other options?
Thanks A
LOUDthud
Re: Impedance switch
Post by LOUDthud »
Is this the switch you are referring to ?
https://www.tubesandmore.com/products/s ... position-0
dorrisant
Post by dorrisant »
That is the one I switched to... Pun intended.
angelodp
Post by angelodp »
Yes that's the one, and only. I see that's Tube Depot actually has a few NKK still avail.
Thanks - time to stock up.
johnnyreece
Post by johnnyreece »
It's not as pretty, but I've used these with success:
https://www.taydaelectronics.com/electr ... -2684.html
I just tie the three poles together. See the attached layout for an illustration. For $1.09, it's hard to beat. Of course, this is a four position switch (which is what I required). They do have three position switches, as well.
LOUDthud
Post by LOUDthud »
You've never burned one of those switches up ? How many Watts have you put through one at 4 Ohms ?
johnnyreece
Nothing more powerful than a JTM 45, and never at 4 ohm (my cabs are 8 and 16). I don't do very high powered amps. Tightwad here.
If you like spending more money and like the flush look, here's another option at a little over $15: https://www.mouser.com/ProductDetail/Sc ... NCShAlI%3D
SoulFetish
Post by SoulFetish »
johnnyreece wrote: Fri Sep 06, 2024 1:07 pm Nothing more powerful than a JTM 45, and never at 4 ohm (my cabs are 8 and 16). I don't do very high powered amps. Tightwad here.
I use these for my voltage and impedance selectors. I like them. I think these are Schurter's updated versions of the Marshall style voltage and impedance selectors. Although, last I checked, they still sold the old Marshall style switches.
angelodp
Post by angelodp »
Very solid piece, thanks for the intel.
A
