FULL DISCLOSURE: Last time I tried following guidance on the internet to do this, it didn't work how I planned. How do I wire the pot in to allow for adjustable bias?
Here is the mod 3 wiring diagram (my kit):
Here's the mod 4 wiring diagram:
The mod 4 bias wire heads into the bias pot's center lug and appears to be attached on one side to the standard 56K resistor, and completely unattached on the other. I've seen adjustable bias pots where the other side is wired to the bias divider (like the mod 3 diagram), which is the way I "believe" I wired my previous attempt. In that setup, the un-trimmed bias was low to begin with, and when I turned the bias pot "up", the bias current got even lower. I used a TAD Bias Master to do all the measuring. If I do it the mod 4 way and choose a 56K resistor connected to the pot, is that enough bias to run KT66? I imagine that's why this version is setup that way, but I'm still a nooblet. That's why I'm asking. Which way is better?
What else would you consider when running KT66 in a JTM45?
THANK YOU!
