CE Distributions new chassis need front panel info
Anyone made a faceplate and backplate for the CE Distributions chassis see pdf below?
No need to start new if some one has and I can get the panel layout from you.
Re: CE Distributions new chassis need front panel info
I want to go input, bright switch, volume, bass, mid, treble for ch1
gain, bass, mid, treble, master volume, presence for ch2
standby, power, fender pilot
10 pot holes spaced 1.5"
Would make a nice 50w or 100w two channel amp. :)
dcribbs1412
Post by dcribbs1412 »
Almost grabbed one with my last order
for a SSS style build,still might(also have SLO boards)
looks like a SLO chassis
Is it decent?
Darin
hylaphone
Post by hylaphone »
I'm not seeing this on CE's site -- have a link?
dcribbs1412 wrote:Almost grabbed one with my last order
Is it decent?
Darin
Very nice chassis yes.
hylaphone wrote:I'm not seeing this on CE's site -- have a link?
It is under enclosures; pre-drilled https://www.cedist.com/products/P-HCH01
dorrisant
Post by dorrisant »
Whatcha building Mark?
Two channel amp Fender clean channel one and Marshall high gain channel two. Something like a Soldano Lucky 13 50w.
But I think I'll use this chassis for a 150w four KT88 two channel fire breather for a local player that uses 5150 amps.
Gaz
Post by Gaz »
M Fowler wrote:Two channel amp Fender clean channel one and Marshall high gain channel two. Something like a Soldano Lucky 13 50w.
...Wonder if that can support 150W iron. It looks to be aluminum, so it just depends on the gauge I guess and how close you mount the iron to the edge.
No problem handling the iron besides I can always add blocks on the ends.
