Preamp section and power section
jestaudio
Post by jestaudio »
is it possible to mix and match preamp sections and power sections, ie use the power section and PI off say RJ's rockster and marry it up to the preamp section off a express or maybe a fender bassman etc, basically what i,m attempting to do is mix and match on a test bed before building a complete amp
Firestorm
Re: Preamp section and power section
Post by Firestorm »
Yes. Preamps are voltage gain sections; power amps are power gain sections. Mix anything you want.
jestaudio
Post by jestaudio »
Firestorm wrote:Yes. Preamps are voltage gain sections; power amps are power gain sections. Mix anything you want.
Cheers, i was pretty sure there would'nt be a problem, next stop a express pre into cathode biased 6l6 power section :D
Firestorm
Post by Firestorm »
Cheers, i was pretty sure there would'nt be a problem, next,, stop a express pre into cathode biased 6l6 power section :D
You want to be a little careful. Don't push the grid signal so hard it drives the grids negative wrt the cathodes. The tubes want to go AB2. Sounds funny unless you design for it.
skyboltone
Post by skyboltone »
And if you don't understand what Firestorm is saying here then you probably shouldn't mix and match. Not to say it's rocket science mind you, just that different power tubes have different drive requirements.
jestaudio
Post by jestaudio »
skyboltone wrote:
Firestorm wrote:
jestaudio wrote: Cheers, i was pretty sure there would'nt be a problem, next,, stop a express pre into cathode biased 6l6 power section :D
hence the reason for using RJ's rockster power section, gives me a chance to try out tubes you would,nt normally use in a express build
pdf64
Post by pdf64 »
Did you mean 'grids POSITIVE wrt the cathode?
Assume you were refering to the power tube grids.
Pete
Firestorm
Post by Firestorm »
