Silvertone Schematic
passfan
Post by passfan »
I have an old EL84 Silvertone stereo amp in for restoration and came across something unique I wanted to run by some here. The amp has global negative feedback taken off the 8 ohm tap , run through a2.7k / .1uf back to the cathode of the input triode. Is this common on stereo amps of the 50's and 60's ? I've never run into it before.
"It Happens"
Forrest Gump
passfan
Re: Silvertone Schematic
Post by passfan »
Found a schematic for the amp
"It Happens"
Forrest Gump
I think it is fairly common for all push pull tube amps to have some form of negative feedback.
passfan
Post by passfan »
Is it normally applied to the cathode and not the grid ?
"It Happens"
Forrest Gump
gary sanders
Post by gary sanders »
Curious,what model is your Silvertone?
tictac
Post by tictac »
It's normally applied to the cathode as shown. See Fender Princeton and Princeton Reverb for comparison...
passfan
Post by passfan »
Have no idea the model number. I got lucky over at DIYAUDIO and found a schematic. I'd not spent a lot of time doing stereo circuits. Thanks for the info
"It Happens"
Forrest Gump
