which tubes that suit for fender pro reverb aa165
plysters
Post by plysters »
just change set of tubes.sovtex 5ar4,n.o.s. 6l6,ehx 12at7,sovtex 12ax7lps.
after I change it,my stock pro reverb turn too bright.
I suspect that 12ax7 lps is not suit for guitar,right?
่ีjust change 5ar4 to old nec and it's sound better.
Do you any suggestion Pls help?
thank
billyz
Re: which tubes that suit for fender pro reverb aa165
Post by billyz »
What did you set your bias too ? try 70% of max plate dissipation. Also, I find the 12at7 PI to very critical to getting a good fat tone from a fender. Try a NOS or good vintage tested 12at7 . I prefer RCA but others work as well or better like Amperex, Telefunken, Mullard, GE's are very good. A JAN GE 12at7(6201) is usually very tightly balanced section to section and low noise, Pretty cheap too. JAN Sylvania's are good too.
8)
aclempoppi
Post by aclempoppi »
Usually priority is the key for me. If you primarily play through the Vib channel, then a RCA 7025 in the V2 position would be my choice for a single coil type guitar. For the PI, RCA 12AT7's are hard to beat. NOS 5751's, matched GE 12AT7, and JAN GE or Phillips 12AT7's are also good choices. IMHO 70% plate dissipation for NOS RCA or GE power tubes, is not necessary for a good tone. But that's your call. Art
None of Us is Free, if One of Us is Chained
billyz
Post by billyz »
It is true 70% bias is not necessary for good tone. But if he has them biased too cold they can sound thin. 70% sounds good 99% of the time.
Heck, I actually like em hotter than that.
8)
plysters
Post by plysters »
thank for every suggestion : )
Bob-I
Post by Bob-I »
plysters wrote: ่ีjust change 5ar4 to old nec and it's sound better.
thank
I'd bet that the bias point changes with the new tube. Check the bias with the old tube, swap to the new one and match it.
If that doesn't do it, I'd look for a NOS rectifier. The new one is most likely not supplying the proper voltages and current. I hear a big difference in my AB763 amp with a NOS rectifier, warmer and richer.
