London Power Standard - finished pic and soundclip
V2
Re: London Power Standard - finished pic and soundclip
Post by V2 »
stephenl wrote:V2 - After rolling a bunch of tubes through the preamp, I found that a JJ 12AX7MG for V1 and JJECC803 for V2 sounded best to me. I tried some Mullard and TungSols as well but didn't like them as much. Did you use the LTPI from TUT5? The latest version uses a gain stage + Cathodyne PI - I used a 12AU7 w/ appropriate plate/cathode resistor changes. I used .022 coupling caps throughout. Since I didn't include the effects loop or reverb, I added attenuation between V2 and the GS/CathodynePI.
Maker - I look forward to hearing how the D-Pre turns out.
Just to clarify, my amp was quite a bit different than the Standard, although I used Kevin's 10-Watt transformer set.
I did use a LTPI, but I'd have to look at TUT5 to see if the values were similar.
stephenl
Post by stephenl »
Hi Ian,
The OT I'm going use has UL taps but doesn't have the cathode feedback windings. I will probably just wire it up for pentode mode though. I have switchable UL / pentode mode on my first one and find myself using pentode mostly. UL mode sounds good, very tight, but I prefer pentode.
The OT is a 50w, 4.2k primary toroid from KOC.
Steve
gingertube
Post by gingertube »
Steve,
My experience too with U/L output stages.
I like U/L mode but only when I also disconnect any global feedback.
Otherwise too tight for a git amp.
Ian
