I belong to Ampegv4.com There's not much traffic, but a lot of info there, nonetheless.martin manning wrote:Very nice, Jay! How did you determine the values for the inductors?
I will copy in a section about the tone controls. My schematics don't show the numbers properly, however, you can look at Ampeg's.
"Okay, so for anyone interested I have the cap/resistor values for the encapsulated module.
It's actually the same module as the SVT of the same era, which I found a schematic for
with values on. And I've verified that against my SVP-CL which uses discrete components,
so they all stack back.
Pin 1-2 470pF
Pin 1-3 220K
Pin 3-4 0.001uF
Pin 4-5 0.01uF
Pin 5-7 22K
Pin 6-7 0.0047uF
The inductor is 800mH, tapped at 100mH and 300mH.
Pin 4 is common, pin 3 is 100mH, pin 2 is 300mH and pin 1 is 800mH."
I scored a V2 for $300 a while back. B+ is about 585Vdc. I wouldn't build one like that. I think I'd want to use a Twin Reverb PT or a sub-500V Hiwatt 50W PT.
