Shared screen resistor question
Re: Shared screen resistor question
Reeltarded wrote:Aha. I based what I said on lots of assumptions. You know what they say. If you assume you make an ass out out cbass.
:P
Edit: :twisted:
Firestorm
Post by Firestorm »
Looks like two of the tubes are being sacrificed on the altar of tone. Nothing between the screens and AC ground. I wonder if a screen short would turn the 390R into a fuse before it turned the fuse into a fuse.
Both, it appears. Not fused with a slo fuse either f3A
This is why I don't like 84s even a bit. The tubes are fragile and the amps they build around them are built like cardboard cowboys.
Ping. Ping. Pow.
Cameron
Post by Cameron »
cbass wrote:Bad filter cap could cause that resistor to blow too.
These things are known to have bad filter caps. It may have been a bad run of caps but 3 out 5 I've looked at needed some caps changed out. Check them.
Also use 2.2k screen resistors with el84s...the tubes will run with less trouble.
