bcmatt wrote: ↑Thu Jul 10, 2025 4:59 pm
So the max cathode to heater voltage on a 12ax7 is 180V.
Not always. Some are rated as low as 100V and some as high as 200V, and the positive and negative limits may be different.
Oh, interesting. I guess I shouldn't assume. I should check what I have in that position. I popped a somewhat modern (less than 20 years old or so) Tung-Sol in the loop position. I just have a box of preamp tubes with varying levels of labels still visible. That one's label was still bold and clear, so it earned a spot in an amp.
martin manning wrote: ↑Thu Jul 10, 2025 6:12 pm
... Some are rated as low as 100V and some as high as 200V, and the positive and negative limits may be different.
I get the impression that the h-k limit is 180V design centre, 200V design maximum
