Fender 3 stage clean to Dumble and Trainwreck?
roberto
Post by roberto »
Hello everybody,
I'm recently working on a three stage clean that was clearly inspired by the Fender Super Reverb ( http://fenderguru.com/wp-content/upload ... _schem.gif ) in terms of voltages and polarizations, but with different voltage dividers.
If it were the Fender it would be:
68k grid stopper
100k 1k5//22u
Fender EQ + Volume
100k 1k5//22u
22n to the voltage divider 3M3//10p and 220k to ground
100k 1k5
I actually modded it to a Dumble-like polarizations:
33kgrid stopper
220k 3k3//4u7
Fender EQ (with 470p treble cap) + Volume
150k 2k2//4u7
22n to the voltage divider 2M2//22p and 220k to ground
100k 1k5
and I whilkst it has less mids than the same preamp with all 100k 1k5, I like the way it takes stomp boxes and how it gently overdrives with my strat.
I would like to know it someone has ever modded a Super Reverb like preamp into something similar, or into a Trainwreck-like preamp with the third stage changed to: 100k 10k directly fed without voltage divider.
Roberto
Roe
Re: Fender 3 stage clean to Dumble and Trainwreck?
Post by Roe »
I have a twin with a wreck channel, although I'm using tweaked k50 specs. It works well. Very dynamic and aggressive sounding. The 3m3/150k voltage divider isn't a great idea - its noisy. I prefer the 2rock JM specs but with a gain pot that adjusts the voltage divider (I'm using this on one channel and the k50 on the second channel)
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
roberto
Post by roberto »
So 1M log pot instead of it, clear, thanks. I've used a 500k log pot in some other builds, with a small pF treble peaker and I liked it, but here I cannot.
