Preamp line out
RWood
Preamp line out
Post by RWood »
Trying to use the search engine for line out returns every post with the word line or out in descending order. After scrolling 5 pages and only finding a coulple useful I decided to start a new thread to save days of searching and quite possibly my sanity.
Question is:
Would tapping a line out from Octal Preamp pin 2 through a .1 600v cap as M Fowler suggested present the same high frequency/thin tone problems as tapping speaker outs? Also what about impedance issues tapping from preamp? Or would going through DI solve impedance issues?
This is for 5B6 Bassman so I really need to retain low freqs. and I don't want changing amp volume for stage volume to affect the board levels when playing through mixer, so preamp tap seems to be best option.
If I need go the speaker out mod, any recommendations as to r1/r2 and cap values would be appreciated.
JazzGuitarGimp
Re: Preamp line out
Post by JazzGuitarGimp »
When you do a search with multiple terms, make sure you select the "Search for all terms" button is selected (this is not the default setting, so you have to select it). This may or may not help, as there are a boatload of posts here. Adding more search terms may help in some cases.
RWood
Re: Preamp line out
Post by RWood »
Thanks, just tried that and returned same results.
Thought I was up on most databases as I was once an ACCESS programmer.
Re: Preamp line out
Google; paste this string:
Variable line out site:ampgarage.com
RWood
Re: Preamp line out
Post by RWood »
This worked great. Found the one that worked for me first return.
Admins should post this technique in search header info.
Problem solved...Thanks.
