Do I shield both OD Drive wires??
markmalin
Post by markmalin »
Hi guys,
I'm building my second D'Lite style amp and while wiring it up noticed that on the original one I built I had shielded cablet going to both the wiper and the one side of the OD Drive pot. Looks like in the layout diagram a shielded wire should only be on the connection from the wiper to V2. Will haveing that other wire shielded effect the tone? I'm considering not shielding that one on this chassis I'm building up -- but wondering if I should re-wire it with non shielded on the one I already built.
Thoughts?
Thanks,
Mark.
"...there are flying v's and then there are the ones shaped like peanuts..." - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
Zippy
Re: Do I shield both OD Drive wires??
Post by Zippy »
Shield it if you need the noise reduction. Don't shield it if you are concerned that the capacitance of your cable is killing tone. The further along the signal chain, the less of an issue it becomes. Good lead dress may obviate the need for shielding.
Deric
Post by Deric »
The "real deal" uses 2 shielded wires. Some say the extra capacitance helps smooth out the overdrive.
Deric®
markmalin
Post by markmalin »
Thanks for the input, guys. That helps.
Mark.
@MalinAmps
markmalin
Post by markmalin »
double post - sorry
@MalinAmps
