FET Board...
				v00d00blues79
FET Board...
Does anyone have a close-up picture of their completed FET board or a layout they could post of the FET board that came with the Funk chassis?  I'm trying to finish mine up and thats the last item on the list.
Thanks!
Andy
						Thanks!
Andy
- mdroberts1243
Re: FET Board...
Hi Andy,v00d00blues79 wrote:Does anyone have a close-up picture of their completed FET board or a layout they could post of the FET board that came with the Funk chassis? I'm trying to finish mine up and thats the last item on the list.
Thanks!
Andy
My amp happens to be on the bench today, so I snapped a couple pictures... I hope it gives you enough information... it is a tight squeeze around that area!
The components changed a bit in the final pic due to biasing the FET.
									-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
				v00d00blues79
Re: FET Board...
Thanks!
Andy
						Andy
- mdroberts1243
Re: FET Board...
Good luck with it... one more caution... ignore the wiring of the input jack in the older picture, I made a dumb error when I first assembled it and got the wiring wrong... you can see it changes in the newer pic.v00d00blues79 wrote:Thanks!
Andy
-mark.
- Funkalicousgroove
Re: FET Board...
So Sorry Andy!!  I went and took pics when we talked, and then my computer at home took a dump, I got it fixed and completely spaced your pic!
FWIW, if you use a 13E Jack (Isolated break, all metal) it's not such a tight squeeze at all
						Re: FET Board...
Deleted
				v00d00blues79
Re: FET Board...
No worries man! I figured you were busy as hell with business since the LC thing went down.Funkalicousgroove wrote:So Sorry Andy!! I went and took pics when we talked, and then my computer at home took a dump, I got it fixed and completely spaced your pic!![]()
Its taken me forever just to get to this point... hell... I still have to order transformers... I think this is the first time in history I've had the head cab before the transformers...
Andy
- mdroberts1243
Re: FET Board...
Funk's post reminded me that he had already given us pictures of stuffed boards... a long time ago... dug this up... much clearer than my own in-place-pics.Funkalicousgroove wrote:So Sorry Andy!! I went and took pics when we talked, and then my computer at home took a dump, I got it fixed and completely spaced your pic!![]()
									-mark.
- Funkalicousgroove
