Obvious Manufacturer srewups
heisthl
Post by heisthl »
I've gotten a few over the years and it's entertaining to hear about others - I'll start by posting a picture of a transformer - I just received 5 of these and they all have the same problem. Must be a new guy at the plant. What's wrong with this picture?
www.RedPlateAmps.com
jelle
Re: Obvious Manufacturer srewups
Post by jelle »
Hmmm, those wires look long enough to pull it off :lol:
briane
Post by briane »
transformer screws(#8's I think) upside down.
heisthl
Post by heisthl »
Wires are fine keep looking. imagine you are putting this in your next build.
Edit - yup that's the problem - I will have to remove an reinsert, something I hate doing 'cause it might screw up the potting.
jelle
Post by jelle »
I was a bit cryptic...
I meant that the wires are long enough to install the PT upside down.... :wink:
heisthl
Post by heisthl »
jelle wrote:I was a bit cryptic...
That's a great idea - if I can figure out a way to call that a "feature".
Funkalicousgroove
Post by Funkalicousgroove »
You won't hurt anything removing the screws, I do it all the time. :D
Yes, I've read of guys pulling the bell ends to stuff un-used wires inside.
Allynmey
Site Admin
Post by Allynmey »
I routinely replace the screws for longer ones depending on the chassis I use.
Are you sure that it isn't just the screws are backwards or are the bell ends actually on the wrong ends?
LooseChange
Post by LooseChange »
Structo wrote:Are you sure that it isn't just the screws are backwards or are the bell ends actually on the wrong ends?
ditto
RevD
Post by RevD »
Looks like the screw heads are on the wrong end. :lol:
Regards,
Dyna
heisthl
Post by heisthl »
Guys this is a power transformer. If the bells were on the wrong ends
1. there wouldn't be a hole
and
2. the exit wires would have to pass through the core to get out.
LooseChange
Correction: The screws are in backwards and that's it.
highway31
Post by highway31 »
these trannies are for lefties?!?! :wink:
