Glaswerks Zingaro
glasman
Glaswerks Zingaro
Post by glasman »
Hey if any of you are in the Austin area. Stop by Austin Guitar House, OZ is handling my amps now and if you want to take a look at one he has a 25 Zingaro on hand.
Gary
About 5 miles south of I-94
www.glaswerks.com
glasman
Re: Glaswerks Zingaro
Post by glasman »
A few ZIngaro pictures if you have never seen one.
Entire amp is built on two board. main and power supply. Includes Active loop and no-load reverb.
Gary
www.glaswerks.com
Very nice cosmetics, Gary. But now you've mentioned the boards, I want to see!
glasman
Post by glasman »
As requested
This is from the protoype. Built in a Princeton chassis.
Gary
www.glaswerks.com
erwin_ve
Post by erwin_ve »
Nice work Gary! Does the Pcb save you a lot of work when building?
Nice to see the layout of components is recognisable compared to eyelet lay-out often seen in this part of the forum .
No push/pull pots?
Very compact and complete amp!
glasman
Post by glasman »
erwin_ve wrote:Nice work Gary! Does the Pcb save you a lot of work when building?
No push/pull pots?
In the end, not really. Still have to measure, form install and solder every part lol.
Next gen of the boards I will modify slightly, splitting out a couple of grounds and other small tweaks.
But it does make the amps consistent. And that is the nice part.
With all the hardware and trannies in place it takes about 30 minutes to install the power supply board, maybe less and around 1 hour to install the main board between sipping on coffee and procrastinating.
Assembly time for the mainboard take about 1 hour or so, power supply takes about 2 hours and that includes all of the power supply wire to main board and ground.
Probably have 200 hours into the board design, but it was worth it in the end.
I offer them in a Sky, , 70's,HRM, DeLeo and other custom tunings.
I can also add a switchable FET preamp if the customer desires.
Gary
www.glaswerks.com
glasman
Post by glasman »
And Yes NO pushpull pots in the amp.
Notta one.
Gary
www.glaswerks.com
dcribbs1412
Post by dcribbs1412 »
Very sweet little amp package
congrats on Austin Guitar House
glasman
Post by glasman »
dcribbs1412 wrote:Very sweet little amp package
Thanks much. Its nice when they come to you....
Gary
www.glaswerks.com
Deric
Post by Deric »
Looks great Gary!! Zingaroo is at the top of my list of amps I'd buy if I wasn't happy with my own builds!!!
8)
Deric®
