DEEP Switch , is it worth in the Bluesmaster??
seems I don't "hear" it work
Soy de Chile y tu?
						Re: DEEP Switch , is it worth in the Bluesmaster??
Some people may beg to differ and also, there are (commercial) implementations of the Deep Switch that are INCORRECT, so some people's opinions could be off the mark. Anyway, I think the Deep switch works well with the Classic tone stack because it beefs up the (low end) resonance a bit; I also like what it does to the PAB (preamp boost), it tones it down a pinch. When you get to a Blues Master or Skyliner preamp, however, the tone is way fat in the first place to the point that if anyone needs more bass than what's available...well, I wouldn't know what to say.richon wrote:DEEP Switch , is it worth in the Bluesmaster??
I have heard the Deep switch in Skyliner tone stacks in Two Rock amps, they incorporated everything Dumble ever offered: bright, deep, mid, and jazz/rock. To me, the Deep on the Skyliner didn't add anything. I did not hear the Deep engaged in their version of the Blues Master, but I would be inclined to believe it wouldn't add much either.
Now, if you don't "hear it" maybe there's something miswired? I think you should be able to hear it. I would suggest the effect would be along the lines of the difference between palying the amp through a half-open back cabinet (equivalent to Deep off) and through a ported cabinet (Depp on).
Hope this helps,
Gil
My experience is the same. I kind of thought the Skyliner incorporated some of the essence of what the DEEP does.ayan wrote: To me, the Deep on the Skyliner didn't add anything.
Gil
I added DEEP to my Fender Super Twin conversion because I left the tone stack mostly FENDER rather then SKYLINER. In that amp the DEEP switch gives a very very cool tone to the clean sound. Like "Super skyliner" or "blackface Fender" but it does not distort as well, thus the need to have it on a switch, so you can get rid of it if you want to use OD.
I have a Ceriatone built BM HRM and it has so much deep bottom end so I surely don't use the deep switch much sometimes with the OD to see how I like it.
I'm using a Two Rock style 212 with 12-65's and Les Paul.
