robben ford 102 built from schematics obtained here
Just got this honey going, tweeked. Through a Dlator with alessis reverb
Marshall cab w g12t-75 speakers. Hamer studio with crossroads pickups from jim wagner
built into a mid 60's Traynor PA head. Converted to 100 watts with a Carvin output transformer I had laying around collecting dust.
thank you thank you to all those who came forth with info and schematics wow
http://www.youtube.com/watch?v=pL5f8Op2NHw
http://www.youtube.com/watch?v=9TuPb99qDac
http://www.youtube.com/watch?v=hlMDQZ5Z77c
http://www.youtube.com/watch?v=JDG2mpiN_WI
				amplifiednation
Re: robben ford 102 built from schematics obtained here
Sweet clips Jack! That amp sounds really nice and your licks are smoking
									Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
- boldaslove6789
I can Dig it! Sounds Great! Any amp pics?
									Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
						Can you dig it?
				dcribbs1412
Congrats very nice tones
nice chops also
Well done
recording setup?
comments on your tweaks?
						nice chops also
Well done
recording setup?
Thanks for the kind words. I started the build about a year ago and the schematic available at the time had some different values then the one shown below. There were different pot values, maybe a resistor here and there and maybe a cap value especially the snubbers on V2. They were posted as 270 pf, the current schematic shows 250pf. I think the local negative feed back circuit was slightly different.
I had not worked on the amp for at least 6-8 months. It was tearing at me every day I looked at it, but didn't have the stick to itiveness required to see it through to the end. Finally one day I gave in and completed the amp but only after checking to see if the schematic had been updated on the Amp Garage. As it turns out the schematic was updated. So I made some of the changes but not all. I left the 270 snubbers as they were to hard a PIA to get to. Also the LNF resistor values I left at 44Meg instead of 40Meg. The PI balance pot is 20k. Otherwise everything is the same as the schematic above.
I did notice that there is a ground missing on the PAB slide switch on the back panel of the layout. The relay won't function manually without it.
The recording setup was very minimal. A Kodak Zi8 EIS HD camera sitting about 3 feet in front of the Marshall Cabinet.
https://tubeamparchive.com/download/file.php?id=14347
[img 768]http://i967.photobucket.com/albums/ae15 ... 27_127.jpg[/img]
[img 768]http://i967.photobucket.com/albums/ae15 ... 25_121.jpg[/img]
[img 768]http://i967.photobucket.com/albums/ae15 ... 24_122.jpg[/img]
[img 768]http://i967.photobucket.com/albums/ae15 ... 23_123.jpg[/img]
[img 768]http://i967.photobucket.com/albums/ae15 ... 22_124.jpg[/img]
[img 768]http://i967.photobucket.com/albums/ae15 ... 21_125.jpg[/img]
[img 681]http://i967.photobucket.com/albums/ae15 ... 26_120.jpg[/img]
[img
[img
[img
[img
[img
[img
[img
Interesting take on the Ford amp.
You probably couldn't hear the difference between 270pf and 250pf snubbers anyway so you are good there.
Different way to wire the relays.
Not sure if you knew but you can use a 16 pin dual inline IC socket for the relays.
That way you can solder the socket in without fear of melting the relays.
http://www.mouser.com/Search/ProductDet ... 575-199316
But what really matters is where the rubber meets the road and your amp sounds good.
Thanks for the tip and the link. Did not know that.Structo wrote:Interesting take on the Ford amp.
				dcribbs1412
Thanks for sharing Rok
After seeing the turret boards I figured you have some Marshall
experience and after checking your website....wow really nice clips
really like the CD and the BeeHandy clips
I understand the "stick to itiveness" or lack of for these builds...
sometimes for me...I walk away from a build to come back later
with more info and try again.
Keep Rockin
Darin
Keep Rockin
Darin
Nice sounding clips. Good job.
Must have been nice working with all that room in your chassis.
yea there was lots of room in there
thanks for the kind wordsdcribbs1412 wrote:Thanks for sharing Rok
Keep Rockin
