Hi guys,
Anyone know where I can get some faster taper audio pots??   1M and 250k
Thanks!!
						30% taper audio pots
Re: 30% taper audio pots
Hi Dogears,
Very good question! I don't know an answer but there was a tread on the Ampage a few months back on this subject. I remember that it is possible to speed up a pots taper with a resistor across two lugs but more things change when you do this, so it is not always an option.
The only solution I have right now is to use linear pots instead of log if a taper is too slow, but you already knew that....
I would be very interested in these 30% taper pots too.
Jelle Welagen
The Netherlands
Jelle Welagen
The Netherlands
- skyboltone
Hi Scott and Jelle,
This is a WAG I think but I believe Clarostat will make anything you want if you buy enough. Is there enough horsepower in the combined membership here to place an order for 1000 each of a couple of values explicit to guitar amps?
I got a couple of hundred I can pledge to the cause. It would take one of us to administer the thing of course. (Not volunteering) Sale at cost plus handleing and re-imbursment of the investors. That sort of thing?
Probably nuts.
Westlabs does it.
Dan
Probably nuts.
Westlabs does it.
Dan
Hey Scott (I owe you a call, I will return it), I got some CTS 30% 1 Meg pots many years ago (when I built the first few amps) from someone who'd placed a speacial order. Contact info is: <cottonamps@aol.com> Don't know if he had any 250Ks or not, but yes, old Dumbles had old pots and old pots were 30%.dogears wrote:Hi guys,
Thanks!!
 [BTW, CTS will make special orders if you need enough of them]
 [BTW, CTS will make special orders if you need enough of them]Otherwise, you can get some from Ted Weber, his are not CTS though, but all the audio pots are 30%:
https://weberspeakerscom.secure.powweb. ... otsord.htm
Gil
Thanks Gil!   Ya know, I had my bud measure his Dumble up again today and this time we checked tapers.   30%.     I like that since it appeals to my sense of fung shai.
Thanks again... Weber it is!
ayan wrote:Hey Scott (I owe you a call, I will return it), I got some CTS 30% 1 Meg pots many years ago (when I built the first few amps) from someone who'd placed a speacial order. Contact info is: <cottonamps@aol.com> Don't know if he had any 250Ks or not, but yes, old Dumbles had old pots and old pots were 30%.dogears wrote:Hi guys,
Thanks!![BTW, CTS will make special orders if you need enough of them]
Gil
- titanicslim
OK, you guys are doing it to me again.  What exactly does "30% pot" mean?  I can't imagine you are cutting your reefer with 70% oregano or something.
Do you mean the wiper gives 30% signal at mid-point or...
And, furthermore Norton, what would be the benefit?
Dave
Dave
The denunciation of the young is a necessary part of the hygiene of older people, and greatly assists in the circulation of the blood. - Logan Pearsall Smith  (1865 - 1946)
Yep - it refers to the percentage of resistance at the pot midpoint.  A "pure log pot" would be a 10% taper.
Me: Just one more...
Do the 30% taper pots make the lower range more useable ?
