Peavey Donor amp build
Bob-I
Re: Peavey Donor amp build
Post by Bob-I »
Oh, and lose the cap C1
dcribbs1412
Post by dcribbs1412 »
Bob-I wrote:Cap off the low voltage tap and connect only the high voltage tap to the bridge rectifier. Nothing from the PT secondary taps get grounded.
Will do Bob..and report back
Darin
dcribbs1412
Ok when I cap the high voltage CT tap(R/Y wire) I get nothing on the bias.No sound
when I ground the HV CT tap amp works but I only get 250V
any suggestions
Darin
Bob-I
Post by Bob-I »
Ok when I cap the low voltage tap I get nothing on the bias.No sound
when I ground the LV tap amp works but I only get 250V
any suggestions
Darin
Just to be clear, you should have the lead from the fuse to one side of the bridge, the red (hi) lead to the other side, the bridge ground is is solid and the B+ leadnshows nothing?
Measure the AC across secondary leads.
dcribbs1412
Bob
appreciate your time
not sure I'm following you
here's a pic of what I have now.... 2 Red HV taps to diodes splits to bias
R/Y CT is to ground with filter caps
380V across leads
Bob-I
Post by Bob-I »
Ok, that's a full wave rectifier, not a bridge.
Double check the schematic.
dcribbs1412
Bob-I wrote:Ok, that's a full wave rectifier, not a bridge.
Thanks Bob
I'll do some research and see if i can wrap my head around a bridge
I gotta say the amp sounds decent as is, but I know its not right
bummer to stall so close to the end.
Thanks for your time
Darin
If I remeber correctely on these transformers you can use a bridge rectifier on the orange taps to get around -50vdc for your bias.
http://www.hammondmfg.com/pdf/5c007.pdf
This link may help clear things up
dcribbs1412
cbass wrote:If I remeber correctely on these transformers you can use a bridge rectifier on the orange taps to get around -50vdc for your bias.
Thanks cbass
I'll need to figure out which to use...I do have a choke on this build
was hoping to use the orange taps down the road for relays.
Appreciate your time
Darin
You'll want to use the full wave bridge capacito rinput.
Third one down on right
dcribbs1412
cbass wrote:You'll want to use the full wave bridge capacito rinput.
Got it... I have 520V now but the bias went wild.Wondering if a change
of resistor value up from 56k to say 220k would work.Or I need to rework the bias circuit like a marshall (jcm900).
Darin
Bob-I
Post by Bob-I »
Darin
Glad to hear you got it. Yes, try the 220k. You could get crazy and calculate the voltage divider values, or you could swap the resistor and take a wag.
dcribbs1412
Darin
Thanks Bob
I'll try a 220k and see...I feel I'm getting closer
do I need a blocking cap?
thanks for your time
Darin
ToneMerc
Bias taps
Post by ToneMerc »
Darin, I knew I had this somewhere, it used to be available on the Torres site. This makes a good general reference for when you need a make bias suppy from the HT winding.
TM
dcribbs1412
Re: Bias taps
ToneMerc wrote:Darin, I knew I had this somewhere, it used to be available on the Torres site. This makes a good general reference for when you need a make bias suppy from the HT winding.
TM
Thanks TM
much appreciated
Darin
