ODS-101-HRM 100W Scratch Build w/ Pics [In Progress]
- Funkalicousgroove
Re: ODS-101-HRM 100W Scratch Build w/ Pics [In Progress]
Dude, you have the patience of Job to sit and drill all that out by hand!!
I did one or two like that years ago-never again!
Looks great!
Looks great!
6L6s generally operate in the 40-50ma range, correct?heisthl wrote:Power = E x I or P = (R X I) x I so if your tube was running at anything less than 223ma you would have (1 x 223ma) x 223ma or .49watts.
I've been jonesin' to build something ever since I registered in '06, and any way I could cut price (obviously I consider my labor as being worth nothingFunkalicousgroove wrote:Dude, you have the patience of Job to sit and drill all that out by hand!!
Looks great!
I'll be the first to admit that this is one of the dumbest projects for a first build, and even dumber to scratch build it, but I figure if I can get this to come out I'll be ready for anything.
In any case, thanks for the kind words.
I'm not looking at a tube manual but IIRC max at full signal is around 150ma per tube before meltdown.benoit wrote:6L6s generally operate in the 40-50ma range, correct?heisthl wrote:Power = E x I or P = (R X I) x I so if your tube was running at anything less than 223ma you would have (1 x 223ma) x 223ma or .49watts.
www.RedPlateAmps.com
So you're saying I can't melt the resistors without blowing the tubes first?? DAMN DAMN DAMN!heisthl wrote:I'm not looking at a tube manual but IIRC max at full signal is around 150ma per tube before meltdown.benoit wrote:6L6s generally operate in the 40-50ma range, correct?heisthl wrote:Power = E x I or P = (R X I) x I so if your tube was running at anything less than 223ma you would have (1 x 223ma) x 223ma or .49watts.
As heisthl has shown, at idle the current is not that high. I wonder about the peaks and valleys of voltage and current during operation with an AC signal (just asking, I don't know).
I guess we should ask heisthl how big of a resistor he uses on his amps
For me, I'm a 'monkey-see-monkey-do' type so I'll be using 5W.
Heisthl is the MAN
So... I thought my chassis was just too thick for faceplates. Good thing for me, I was completely WRONG! Heisthl took my visio drawings (which I figured were just wishful thinking) and printed some fantastic looking stick-on faceplates. I've been busy lately so I just got them attached. It was a pain because I'd already installed the XLR footswitch jack, which mounts to the outside - I had to completely desolder
It's all done now, and the thing looks pretty ok!
So thanks a bunch Heisthl.. without further ado, the pictures:
bluesfendermanblues
Fine looking amp - where do you get the XLR connector on the back - is it a switchcraft?
I believe I got it from mouser, and yes, it is.bluesfendermanblues wrote:Fine looking amp - where do you get the XLR connector on the back - is it a switchcraft?
Nice looking build!
Very cool of Heisthl to hook you up with the faceplates. They look great.
Re: Heisthl is the MAN
Looks great, but why would you call the level control ratio? It is level since it is also a master. Ratio was a non HRM term.
Unless this is now a non HRM...
It would bother my obsessive compulsive psychosis.... LOL
benoit wrote:So... I thought my chassis was just too thick for faceplates. Good thing for me, I was completely WRONG! Heisthl took my visio drawings (which I figured were just wishful thinking) and printed some fantastic looking stick-on faceplates. I've been busy lately so I just got them attached. It was a pain because I'd already installed the XLR footswitch jack, which mounts to the outside - I had to completely desolderIt's all done now, and the thing looks pretty ok!
bluesfendermanblues
Thanksbenoit wrote:I believe I got it from mouser, and yes, it is.bluesfendermanblues wrote:Fine looking amp - where do you get the XLR connector on the back - is it a switchcraft?
face Plates
Is there a tutorial or thread on how yo print out thoes Great looking face plates? I'd like to make them my self instead of going to Kinkos.
Re: face Plates
Not that I know of. Heisthl's the man to ask.toneman wrote:Is there a tutorial or thread on how yo print out thoes Great looking face plates? I'd like to make them my self instead of going to Kinkos.
