bluesfendermanblues wrote:My point is that just becuase a HRM has a set of tone controls after the OD, like a Marshall, it doesn't turn the amp into a marshall and you don't have to play the amp harder than you play a NON HRM. The difference in sound and feel between the two preamps is not that severe, IF you dial in he HRM to sound NON HRM'ish, but there's a lot of tonal options in those three trimmers
A valuable point - thank you.
For my own clarity, here - a Skyliner EQ is a non-HRM post-OD tone stack? (being a feature creep, the extra tone stack appeals)
Or is the Skyliner one of the clean channel tone stack variants?
Since this project is my first trip into the DumbleZone, I do want to cover the range a bit.
It seems Mr Ayan has done so and found a home in the #124. I aim to set out on the same sort of journey, but with fewer chassis crowding up the place.
The PT is a 250-0-250 in a voltage doubler configuration - B+ looks like 650V with a Vscreen of 325V.
Gonna get a good copy of parallels and load Duncan's PSUD to see if I can get to a useable set of voltages with this PT. What are the B+1 and B+2 of the #124?
(While I'm asking, what about those voltages on a BM?)
If I have to get a different PT, I may just punt the conversion and try reworking CH2 to be an OD.
DonMoose wrote:What are the B+1 and B+2 of the #124?
B+1 = 440, B+2 = 438 is what I have written down. BM should be ~same, I would think, and very like a Twin Reverb. Fender schemes list various levels from 440-460 B+1 and 2V drop across the choke..
