completed 100 k amp
Re: completed 100 k amp
Very nice build bigmik.May I ask where did you get the sprague cathode bypass caps?
thanks, I really enjoy making the boards for my build but it would be cool for the guys who don'tM Fowler wrote:Nice job. I wish some one would offer a set of boards for that chassis.
thanks henry coming from you that really means a lot ,as for building it for less ,sure parts wise it's less but if you factored in the amount of time no way,but when I do buy an amp yours is high on the list .but the feeling when you flip the swicth an nothing blows up PRICELESSheisthl wrote:
Easy way to do multiple quotes is right click on the "Quote" icon and select "open in new window". Then go to the next one and do that again. Now you can cut and paste between the 2 windows.
Beautiful work - why buy new when you can build it (hopefully for less).
thanks tomStructo wrote:Beautiful build!
Is that Teflon wiring?
I notice you didn't include the 220K/250pf network on the Send/ Return jacks?
Have you tried that and not liked it?
I'm getting ready to build a Dumbleator and was concerned about that.
yes all teflon wire I love that stuff ,takes a lot of preasure off a shakey pirate like me
never tried the 220/250pf network ,what exactly does it do ? make the amp darker? maybe I try it and see for myself
thanks glasman, again I'm humbledglasman wrote:Very nice workmanship!!
Etching boards can be fun!. I have a RAT tube tester that I layed out, need to get it transferred and etched this week. Nothing like the smell of hot ferric chloride in the morning.
yeah that burning feeling in your eyes is great
thanks ,I'll jump right on it!UltraHookedOnPhonix wrote:Beautiful build! Now go plug that IEC hole up!
those are from mouser here is the pt #75-TE1204dimitris wrote:Very nice build bigmik.May I ask where did you get the sprague cathode bypass caps?
So you used 10uf bypass on all four cathodes?
How is the bottom end as far as, too much, too loose or just right?
As far as the 220K/ 250pf thing on the FX jacks, I believe it is to preserve the high end sparkle when used with the Dumbleator?
Do you have one of these and do you use it?
yep 10 uf on all 4,its cool with a strat borderline to bassy with hb's but I ain't changing nothing yet
no d-lator yet ,but would like to build one eventually
On one build of mine I have a switch that selects different mid caps.  I call this my single-coil/humbucker switch.  Works quite well.  I still like the amp with humbuckers better, but it is okay with a Strat.  The "humbucker" setting with a Strat is too thin.
Me: Just one more...
I did that in my D lite it to be able to select a .01 or a .05 it usually stays on the .01mlp-mx6 wrote:On one build of mine I have a switch that selects different mid caps. I call this my single-coil/humbucker switch. Works quite well. I still like the amp with humbuckers better, but it is okay with a Strat. The "humbucker" setting with a Strat is too thin.
its a beauty
Beautiful build, I bet its a tone machine. On that Dlite switch for the caps, any chance we could see a gut shot of that, I have been edging towards that idea ( with some background help -  wink wink )
cheers Ange
						cheers Ange
Ange,
I will probably put one on my amp as well.
You can either put both caps there and switch between them or wire the switch so it shorts across one of them.
Or put it on a push pull mid pot, but I already have my mid boost on that so a separate toggle will have to do in my case.
I plan on mounting my switch on the top of the chassis above the spot so the wire run will be short.
Here is a schematic, I believe Henry drew this.
If I'm wrong about it then my apologies.
I just uploaded my tubes and more and mouser parts list with part #
hope it helps sombody .
http://community.webshots.com/album/576145900cGFWqU
