Steel String Singer#002 build from Scratch
Re: Steel String Singer#002 build from Scratch
Keep the 2x 100R faux CT or the actual CT, just connect it to the elevated DC voltage instead of grounding it.
timrobertson100
Post by timrobertson100 »
Thanks Martin
Hendrixianer
Post by Hendrixianer »
timrobertson100 wrote: Sun Feb 16, 2025 4:33 pm Perhaps a daft question… you don’t use 100R balancing resistors when elevating the heaters?
There´s no Need for Balancing Heaters if using PT with Center Tap !!! it is already balanced!
DIY Amps: Marshall JTM45,Orange Grafik II 50W,Some 18W Marshalls,Dumble ODS 50W,Hiwatt DR103,Madamp G3 Blues,Dumble Steel String Singer, Fender Standalone Reverb 6G15,a few Hundred Pedals,like Uni-Vibe,etc,etc... :D
Some people believe that even if you have a center tap on the heater winding, a better balance can be achieved with two 100-ohm resistors, or even a pot to adjust the balance. You should use either the actual CT or the resistor CT, never both.
Hendrixianer
martin manning wrote: Thu Feb 27, 2025 11:47 am Some people believe that even if you have a center tap on the heater winding, a better balance can be achieved with two 100-ohm resistors, or even a pot to adjust the balance. You should use either the actual CT or the resistor CT, never both.
Than better use a wirewound Pot,called Humdinger to balance and eliminate Hum........
Hendrixianer
Added 12V PSU and Footswitchable Fet Boost,new 2-Way Foot Switch:
