M Fowler wrote:Anyone have the PPS board diagram that you used Tonemerc, I got mine from jborders but for some reason it is not the same as the boards currently being used and I want to make sure I wire this up correctly.
The six holes on the bottom L to R: 3 on left are for B+1, 4th hole is ground for B+2, last 2 is B+2 positive. Correct:?:
Mark, the board pictured above is not one of Jason's PPS boards. Shortly after the very first run of CE chassis a member here(I forget who now) had some boards made for his personal use. In order to get a better deal he ordered more than he needed, sold off the extras and I purchased a couple of those.
Those boards were setup so that the standby was directly after rectifier, hence they have only six terminations. A traditional board that has the standby after the first capacitor bank node will have 8 terminals and this is what you will normally see. AFAIK, the AGB "clone" boards that Jason has offered to the public all have had 8 terminations, I 've used those as well.
However, a couple of years ago Jason did have some PPS boards made for his personal use which included a 4th power node. Those boards were very unlike(integral fred diodes, loop/reverb node, multiple grounding options)the traditional PPS board that he offers in his clone set. That board does have 6 terminations at the bottom. Do you by chance have one of those boards? I do have the diagram for that one, see attachment.
FWIW, what you don't see above or in the two builds that I've used these in is a 3 eyelet daughter board mounted under the main pwr board that allows me to config the power supply with the same functionality as the 8 termination board.
I wanted it to be transparent, I guess it works
TM
